VRay RT and Material Fog Colour
  • VRay RT and Material Fog Colour
    I cant work out if im wrong or not...Im sure i used to be able to see the fog colour with RT.
    For some reason now for the past few days all i get thru RT is clear glass.
    any ideas ?
    Works for me. Maybe you toggled the new scene scale variation on the fog value? i.e. Maybe it's just a scale issue.
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
      works fine when i render.Just will not show up with RT.
        follow up to this - tested RT with GPU and the fog works..Just will not work with CPU
        Brett did you test with RT CPU or GPU ?
          Which version of V-Ray RT is this?
            im using 2.00.02
              I don't really use GPU so it was CPU for sure. I'm working on a job right now with mats with fog and they are all working just fine. We might be on slightly different builds though.
              b
              Brett Simms
                any ideas Vlado ?
                  Yep, I can reproduce this. Looking into it now.
                    Yep, in early versions material fog works. But now in 2.02 fog in VRay RT CPU and GPU not working (and CPU and GPU give us different render).
                    AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
                    2D | 3D | web | video
                    jiri.matys@gmail.com
                    https://gumroad.com/jirimatys
                    https://www.artstation.com/jiri_matys
                    https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
                    https://www.instagram.com/jiri.matys_cgi/
                    https://www.behance.net/Jiri_Matys
                    https://cz.linkedin.com/in/jiří-matys-195a41a0
                      It's fixed now... if you go to the download page, the build from December 15th is fine.
                        I still seem to have an Problem, but I'm not quite sure if its me, because I am a beginner. Take al look at these Pictures, the first taken from RT with CPU, next one RT GPU and finally the rendered Image.
                        But if I take the wine out of the glass, everthings seems fine, even on CPU. Hope you understand what I mean
                          Can you get me that scene to vlado@chaosgroup.com?
                            you got mail -
                            • #15
                              Thanks - looking into it...
