startup error after going back to 1.5
  • startup error after going back to 1.5
    2 minutes after I installed Vray 2.0 on our first workstation a customer called with an urgent project
    (Murphy.. go die in a fire )
    So I have to downgrade to 1.5 again as I have not the time to install or test 2.0 on our renderfarm.
    After deinstalling 2.0 and reinstalling 1.5 I get a startup error.
    Compile error $startupScripts\vrayutils.ms
    I deinstalled 1.5 again and located that file wich was still present and deleted it.
    After another reinstall the error occurs again.
    Rendering seems to work fine as it seems.
    Anyway, is there something i can do about it ?
    removing the script that left should do the trick. There are two scripts in the startup folder actually "vrayinstall.ms" and "vrayrtinstall.ms". They are both not needed for the 1.5 and 2.0 will install them again but they should work properly with it.
    Could you remove them both? Please write if the problem persists.
    Best regards
    Alexander Kazandzhiev
    V-Ray for 3ds Max developer
      Yep, thank You, that works. I forgot one of the two the first time.
