Alpha problem
  • Alpha problem
    Hi guys,
    got a bit of a problem with opacity mapped leaves here
    rendered image alpha comes out nicely, howevere the RGB pass doesnt!
    no filtering applied to maps
    no AA filtering applied on render
    no bluring applied to maps
    source map of the leaves are OK...the alpha has no white border and the rgb map goes all the way to the sides of the image.
    any idea whats wrong?
    thanks for your help
    Best Regards
    Martin
    Martin
    http://www.pixelbox.cz
    does the leaves mat has reflection on? if so you might need to mask the reflections too, they may be spreading on the whole plane causing artefacts.
      good tip!!! i ll try that!
      THANKS!
      Martin
        yep, it worked! thanks again, actually it was the translucency map causing it.
        Martin
          oh well, glad you sorted it
