Vray 2.0 license on Windows 7
  • Vray 2.0 license on Windows 7
    Hi!
    Can you help me please to let Vray 2.0 license work under windows 7?
    These are the step I've made:
    -A new fresh format system with Windows 7 32bit updated
    -I've installed Vray 2.0 (for 3dsmax 2011 32bit)
    -From the same .exe the WIBU Key drivers are installed
    -Once finished I've put the dongle on and on the taskbar a message says to me it's all right and recognized the dongle
    -I've run "V-Ray license Server" (as Administrator)
    -Finally I've run 3dsmax
    Once opened the Render Settings this error message appears:
    "Could not obtain a license (-200)"
    What's wrong? What am I missing?
    Thank you very much.
    what vray build are you using? that could help explain.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Did you update your dongle with a 2.0 license? If you open the license server web page, do you see the V-Ray 2.0 license there? If not, please email us to vray@chaosgroup.com to fix this.
        Yes.. I've update the my dongle to the last Vray 2.0 version (and I've installed the Vray 2.0 for 3ds max 2011 version too...)
        In the following link I've saved the webpage of the address http://127.0.0.1:30304/
        http://www.ossosso.com/public/scambi...e_server_2.pdf
        Thank you for your support
        P.s.
        No Firewall active
        No Lan Cable attached (to avoid network conflicts)
        No password for my user
          Are you using a beta build?Please download and install V-Ray 2.0 official release from our website and let us know if the problem persists.
          Tanya Metodieva
            No I'm not using a beta building, I've downloaded the official from your website few days ago.
            This is the file I've installed: "vray_adv_20002_max2011_x86"
            Question: an usb dongle is machine dependent? I can use it on a computer but not on another? 'cause I'm working on a Windows XP sp2 64bit system with my usb dongle and Vray 2.0 and all wokrs correctly. Now I'd like to try Vray 2.0 on a Windows 7 32bit system because on this last machine I've a GeForce GTX card and I want to test the RT GPU with the best hardware I have.
              No, the dongle is not locked to a particular machine. Are you sure you are running the license server from the latest V-Ray? Check which license server you are using from Start menu > Programs > Chaos Group > V-Ray for 3ds Max > Licensing > Administration > Change V-Ray client license settings. Then open a web browser and type http://servername:30304 where servername is the same server name (or IP) as in the license settings dialog. Do you see a V-Ray 2.0 license in the license server status page?
                yes, it is.
                This is the page that I see once done what you said:
                http://www.ossosso.com/public/scambi...5018595758.png
                nobody else had "problems" on windows 7? Some option to deal with...
                  I don't think it's related to Windows 7 specifically. Can you email me to vlado@chaosgroup.com, I'll get you a slightly modified build that gives some more information about such problems.
                    Please advise if it is alright with you to arrange an online conference within a convenient time.If so , please e-mail us at vray@chaosgroup.com.
                    Tanya Metodieva
