I found a strange thing happening with environment fog sampling on bright spots (like reflections). Please see image below:
On the left you see the beauty pass with a bright blurry reflection highlight. On the right there are three images with different subdivision values:
#1: 16 samples, you can see a darker area where the big bright highlight is
#2: lowering the subdivisions will results in a more noisy but dark-spot-free pass
#3: same result with really high values
I thought it could be the cutoff threshold and tried lowering it to zero but it didn't change anything.
In another scene I can even see a kind of dark halo around bright spots in the beauty pass. I can't lower or raise the subdivisions there so it's quite a problem.
[edit]
I attached another image where the problem is even visible in the beauty pass (image zoomed)
[edit]
