Textures Wont Load when Distributed Rendering
  • Textures Wont Load when Distributed Rendering
    The system running vrayspawner2011.exe is running as Administrator and I made sure it's bypassing the firewall. But when I render using it, it renders buckets with blank textures. The local machine displays the textures, but the buckets from the system connected as distributed is missing the textures.
    It also has access to the local computer that has the texture and is able to read and write files to the drive. The textures load correctly when running VRay RT, but not Vray 2.0 Any suggestions?
    This could be caused by the User Account Control. Make sure it´s turned off. Also make sure you only have one instance of VraySpawner
    running on the slave machine.
      Disabling the User Account Control has solved this. Thank you!
