NOTIFY_POST_RENDER line 417: VRay::freeData()
  • NOTIFY_POST_RENDER line 417: VRay::freeData()
    After rendering I get the following Error:
    Error: UNHANDLED EXCEPTION: Broadcasting NOTIFY_POST_RENDER last marker is at
    .\src\vray.cpp, line 417:VRay::freeData(),cleaning render settings
    My rendering dialog crashes and becomes unresponsive.
    Im working with 3ds max 2011 - Vray 1.5 sp5
    Intel Xeon X5550 @ 2.67GHz dual quad
    24 GB Ram
    Nvidia quadro fx 4800
    Windows 7 64bit
    In this scene I'm working with "Hair and Fur" on geometry mode.
    Does anyone have an idea?
    Vlado?
      It's a Hair and fur problem. Doesn't matter if I render on Geometry or mr prim.
      This used to work fine, are ther any solution or work arounds?
        I'm not sure without a scene for this; if you wish you can send it to vray@chaosgroup.com and we'll take a look at it.
          ok, I wil strip the scene and send it.
          Thanks.
            I found the problem.
            If you enable the Direct illumination in a VrayLightMtl in combination with vray fur, your render will crash.
            Without this setting the scene works fine.
            The problem wasn't limited to one scene, but occured over multiple projects.
            @ Vlado: I will send the stripped scene to your mail, perhaps it's of use.
            Kind regards,
            Jord
              Yes, if you can get me the scene, it will be very useful.
