Very bad bug with lights !
  • Very bad bug with lights !
    Heya
    Soo well I finally give up and decided to report it. Its definitly vray/standard light bug...
    I'm guessing the shadow cut off is too low and my scene is exploding with artefact's
    Funny thing is Vray-RT-CPU works perfectly
    Vray lights dont have that issue, only standard and maybe photometric....
    Anyway screen below.
Name:	Vray RT 1.jpg
ID:	872619Click image for larger version
    Any chance for a quick fix ?
    Thanx, bye.
    Do you have any more info? I don't understand whats actually going wrong?
    Are you using standard max lights with Vray shadows or Bitmap shadows?
      When you say standard light do you mean the standard omni?
      Also, what are your AA settings?
      Dan Brew
        Look at shadow fallof, with RT is smooth, with production its sharp, edgy.
        Im using spot/omni/etc etc standard max light
        Shadows are Vray SHadows/area shadow /mixed sizes
        AA is irrelevant
        Anyway, finish image here http://www.chaosgroup.com/forums/vbu...here-and-there
          What sort of materials are you using? I looks like it could be caused by reflection cutoff being set too high.
          Nice images on your link btw.
          Dan Brew
            Its not reflection, its shadow, its vray eeee car paint I believe, which is at 0.001 if I'm not wrong with cut off. If I put a Vray light in that same spot I can get that same smooth effects as RT in production ender.
            Thanx
              Ok then; can you get us just that part of the scene with the problems to vray@chaosgroup.com so that we can look at it? I don't need the entire geometry, just the part where the problems are.
                Sure
                Gime few mins I'll make new one, this thing is everywhere ;s
                //Send... enjoy ! Let me know if u can of results...
