Hi
When you have an ies file loaded and you change the power value to something other than the default when adding the IES file, and then repath the ies file, it resets the power value to default. This is rather annoying. If you use a normal Photometric IES light source instead of VRayIES, this doesn't happen, which leads me to believe it is a bug with VRayIES
(In other words when you add a VRayIES the default power value is 1700, when you add an IES file the default for that file is for example 5000. Now 5000 is too high or too low so you change it to say 3000. Now move the physical path of the IES file and repath it either in the VRayIES Parameters or even in Asset Manager, and then power jumps back to 5000)
