batch rendering saving with VFB ...
  • batch rendering saving with VFB ...
    Vlado is there any way you could add option while using max batch render to save through VFB.
    It's saving through max frame buffer and it doesn't burn in color curve modification I do in VFB.
    Luke Szeflinski
    :: www.lukx.com cgi
    old request
    new demand !
    Thanks
    (Sorry for my bad english)
      I guess you'd have to enable the "split channels" option in the VFB and then specify different output images for each batch render (not sure if this is possible though).
        No way with VFB
        The only way is to use max frame buffer.
        The main problem for me is to not be able to use VFB with batch render because you can't save anything than full render (I don't render in EXR)
        I mean, you can't have render elements saving if you don't switch to max frame buffer.
        By the way, as said Lukx, you can't use color curve modification in VFB...
        Perhaps, I misunderstood something ?
          I have just tried this with the psd-manager 3.1 Beta and its working. If PSD files are an option then the V-Ray framebuffer support in the upcoming psd-manager 3.1 update will allow to save render (with the color adjustments from the V-Ray framebuffer), render elements (and also Lens Effects) using Batch render.
          Daniel
          Daniel Schmidt - Developer of psd-manager
            Thx dans for your response I don't have and don't want to use psd manager.
            I don't want to use anymore maxframe buffer!
            Vlado, can I ask you if in a roundabout way, it's possible to use fully batch render with Vfb ?
            Is it something possible to be implement ?
