script error on startup
  • script error on startup
    since installing the vrayrtutils animation script - i've been getting the following error on startup:
    Code:
    -- Error occurred in autoinstallVRayRTUI(); filename: C:\Program Files\Autodesk\3ds Max Design 2011\scripts\startup\vrayrtinstall.ms; position: 198; line: 6
    --  Frame:
    --   thisFile: undefined
    --   updateVRayRTMenus: undefined
    -- Error occurred during fileIn in <File:C:\Program Files\Autodesk\3ds Max Design 2011\scripts\startup\vrayrtinstall.ms>
    >> MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max Design 2011\scripts\startup\vrayrtinstall.ms Exception: -- Type error: Call needs function or class, got: undefined <<
    and a pop-up window which shows "Type error: Call needs function or class, got: undefined"
    when the going gets weird, the weird turn pro - hunter s. thompson
    to stop the error from appearing you can delete the "C:\Program Files\Autodesk\3ds Max Design 2011\scripts\startup\vrayrtinstall.ms" file. It is there just to install automatically the V-Ray RT menu items and is not needed. The only missing thing might be the "Make V-Ray RT Animation Preview" at the bottom of the "Rendering" menu. Executing updateVRayRTMenus() from the listener window should fix it if no errors occurred.
    Best regards
    Alexander Kazandzhiev
    V-Ray for 3ds Max developer
      seems to have fixed it! thanks!
