VRay camera creating FOV and Focal Length keys just by moving timeslider
  • VRay camera creating FOV and Focal Length keys just by moving timeslider
    I have a scene with several animated cameras. All VRay cams, but some on a path, others free cameras, and others targeted.
    I'm getting a weird behavior where if I turn on AutoKey and move the timeslider, Max is creating a key for the FOV and sometimes the focal length at the point moving the timeslider. It's also keying *unselected* cameras in the same way, but only some of the cameras. The keys themselves are only changing the values very slightly, like changing the FOV from 55.0 to 55.02 and 55.04, if at all (sometimes just sets a key at the same value).
    All this is without touching any of the camera parameters, just scrubbing the timeline with auto key turned on. I have cameras with and without animated focal length, with and without locked FOV, and there seems to be no rhyme or reason to the issue.
    Has anybody else run into this behavior?
    SJ
    Yes, we have also found this bug, I hope it gets fixed soon!
    g
      It seems to be fixed in Max 2012! still using 2010 ;(
      g
        We have fixed the problem. A build with the fixed problem can be provided by request to vlado@chaosgroup.com.
        Thanks for the feedback.
        Alexander
        Alexander Kazandzhiev
        V-Ray for 3ds Max developer
          Hi
          Hopefully we are upgading to Max 2012 very soon, so I will hang on for now!
          Thanks
          g
            i have the same problem.
            Not possible to animate a Vray camera with animated foV,
            because everytime i use the timeslider in autokey Mode,
            it will set a unwanted keyframes.
