DR IM precalculation - only first frame rendered with all nodes
  • DR IM precalculation - only first frame rendered with all nodes
    i searched for this subject but could not find solution.
    I am trying to render IM prepass using DR but only first frame gets rendered with all nodes. Next and all other frames are rendered only with one computer, pc that i started rendering from.
    I have checked the log and all looks fine there. I am doing DR all the time and it works OK all the time.
    Doeas anyone have an idea what could be wrong?
    I am up against a deadline and any help greatly appretiated.
    Thanks very much!
    max 2011 64/ vray 2
    EDIT
    this is end of a log txt from one of the render nodes. Does this look ok?
    Does this [2011/Mar/14|20:33:19] Image prepass completed line from the end of the log means that the prepas rendering has finished?
    thanks
    [2011/Mar/14|20:01:14] Irradiance sample size is 84 bytes
    [2011/Mar/14|20:01:14] Broadcasting NOTIFY_PRE_RENDERFRAME.
    [2011/Mar/14|20:01:14] beginFrame() done.
    [2011/Mar/14|20:01:14] Broadcasting NOTIFY_BEGIN_RENDERING_ACTUAL_FRAME.
    [2011/Mar/14|20:01:14] Photon size is 56 bytes.
    [2011/Mar/14|20:01:14] Light cache sample size is 120 bytes.
    [2011/Mar/14|20:01:15] 7 interpolation maps registered
    [2011/Mar/14|20:01:15] Rendering interpolation maps with minRate=-3 and maxRate=0
    [2011/Mar/14|20:01:15] Setting up 16 thread(s)
    [2011/Mar/14|20:33:18] Threads completed
    [2011/Mar/14|20:33:18] Calling endPass() on irradiance maps
    [2011/Mar/14|20:33:18] Calling prePassDone() on irradiance maps
    [2011/Mar/14|20:33:19] Image prepass completed.
    When i press escape to cancel rendering prepass, than i see brown message in the vray message window "server (ip address) starting frame ..." for all render nodes and than everything gets canceled
      for me it works only when using "incremental add to current map".... the imap will not saved during rendering, it´s been written only into the RAM. on render end, I save the imap file manually from the render dialog... this my work arround to use DR for prepass calculation...
      regards
      chris
      www.vis-art.de
      www.facebook.com/visart3d
        Thanks Chris very much! I'll try this now
        EDIT
        it is not working... still the same.
          quick update if anyone is interested...
          i have contacted vray and was told that they were able to recreate this problem at their end and are working to solve it.
            update: If it´s a camera flythrou with static elements, just tick " use camera path" an render out one Frame... It calculates the whole animation prepass DR in one pass....
            www.vis-art.de
