Animate a vray light with bitmap applied
  • Animate a vray light with bitmap applied
    hi i seem to be struggling to try and animate a vray light material with bitmap attached to it.....basically i want to show a colour change effect on a lightbox, i have 3 images the same but have changed the hue and want to see the colour change animated...can this be done ??
    I know you can animate a diffuse colour but thats no good as i want to show the graphic illuminated
    thanks
    Tony
    well you could either animate a colour correct modifier over your bitmap, or just animate the colour in aftereffects or something and save out an image sequence.
      thanks,
      i just mucked about with the output ' enable colour map' section of the material and changed the RGB colours...works a treat )
