Render elements not saving using VFB, but work with max fb
  • Render elements not saving using VFB, but work with max fb
    Hello, I am having some issues saving out render elements. Works fine with the max frame buffer but when I use the VFB they aren't appearing. No idea why.
    Searched the forums for tips or info, and it's not a RAM problem as I am rendering at 70x40 resolution as a test but still with nothing. When I check the channels in the VFB I can save out the images by hand, so it's got the images in memory or what have you, but it's not writing them to disk. Tried net render and local but nothing.
    Anyone have any idea what I did wrong here? I'm sure it's something easy.
    You currently need to save via the raw image output options / split render channels options in the Vray render dialog rollout. That needs to be set pre-render, otherwise for the time being you have to manually save each channel.
    /b
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
      Fair enough. Thanks for replying.
        What about for animations. Same technique?
          Yes it works just fine for animations. I just didn't realize that how this worked changed with Vray 2, but it's easy to do once you know.
