Problem With VrayLight As Skylight Portal
  • Problem With VrayLight As Skylight Portal
    There is an issue with the Vraylight as you see on the image- I put the red rectangle around the problem area.
    If the "simple" feature of the portal is unchecked, it renders with a strange line in the middle.
    (The material is RGB 128 grey on the whole scene- no material difference or reflections.)
    for my blog and tutorials:
    www.alfasmyrna.com
    Do you have any maps or anything in the environment slot?
      Default VraySky in the environment.
      www.alfasmyrna.com
        Never seen this one before. Does it go way if you hide your ground plane or turn off maps in the environment slot and just use white?
          The line appears at the horizon line of camera.
          It goes off when there is no ground plane. But I need the ground plane so it is not a solution.
          Probably this is a bug.
          www.alfasmyrna.com
            Can you get us a scene for this to vray@chaosgroup.com ?
              Sorry for my late reply- I already sent the problem file to your email.
              Looking forward to hear from you and thank you
              www.alfasmyrna.com
                No news ? Nothing?
                I sent the scene but got o reply.
                The bug still continues in the SP1 too.
                www.alfasmyrna.com
                  Vlado ? Or anyone from Chaos Team?
                  I am still waiting to hear from you about this problem but nobody ever replied me almost 10 days
                  www.alfasmyrna.com
                    Must be busy. If you want it debugged by _not_ chaosgroup, post a simple scene here with the problem . I'll take a look.
                    Colin Senner
                      Hi Colin
                      Thanks for your care.
                      As I told above, the problem appears when using the ground plane.
                      Here is the file :
                      www.pixela-3d.com/x/One_Chaos.rar
                      www.alfasmyrna.com
                        I have had this exact same problem over the last 2 jobs, see attached. You can notice it most on the right hand side walls.
                        Deleting the Vray Plane fixes the problem, but I would like to still use it?
                        Has anyone got a solution for this.
                          If you put a normal plane instead of a vrayplane, the problem still continue.
                          Moreover deleting the Vrayplane only works sometimes.
                          I contacted Vlado long time ago about this, and sent the file and he told me they are working on it but no news and no solution.
                          www.alfasmyrna.com
                            Well, it was a bug, obviously. It's fixed now and I can get you a build next week if you email me to vlado@chaosgroup.com
                            • #15
                              Thanks Vlado, fantastic.
