3dsMax 2011 - Crash when loading render preset
  • 3dsMax 2011 - Crash when loading render preset
    As I posted here. It seems it may be a VRay issue.
    http://forums.cgsociety.org/showthre...ghlight=preset
    Do you have the "Compress files on save" option enabled in the 3ds Max preferences?
      Yeah that's on - why would it affect it?
        Try turning it off... presets are in fact, regular 3ds Max files, so the compression option affects them.
          It worked! Thanks.
            OK we are having this issue now with Max 2015 and VRay 2.5
            Compression is OFF
            This could possibly be related:
            http://forums.chaosgroup.com/showthr...-License-Issue
            Any more ideas?
            Kind Regards,
            Morne
              Does the crash appear if you load it on empty scene?
                Yes it does. But again, it's random. I'm suspecting a VRay license issue, but can't be sure yet
                Kind Regards,
                Morne
                  Doesnt look like this is license related.
                  But it keeps on happening. On average about 50% of the time, it crashes max. Well max hangs, task manager says CPU is busy at 8% but it just sits there. RAM usage also just sits there, doesnt go up or down
                  Kind Regards,
                  Morne
                    Would it be possible to attach the preset for investigation then?
                    Do you know what steps that we should follow in order to reproduce the issue?
                      Here's the file. Put it somewhere on a server, not your local pc.
                      ps.zip
                      Nothing special for the crash, just load it. With an empty scene and also with a heavy scene. Half the time it crashes
                      This is with max 2015 and VRay 2.5
                      I also have other presets, it does it with all of them. And also on different workstations
                      Kind Regards,
                      Morne
                        Alternatively, I can use maxscript to set all the settings. Will this still work IF there is no license available?
                        Kind Regards,
                        Morne
                          Yes, it works.
                            [ATTACH]20615[/ATTACH]
                            I made a test on several machines with your preset (loaded from a network location) and was not able to replicate it.
                            Does your machine become responsive after a while ?
                            Tashko Zashev | chaos.com
                            • #15
                              No it just sits there. Task manager CPU is stuck on 8% and ram doesnt move. Left it for 15 min, nothing happens.
                              Will test it a bit later purposely without a license and see if it hangs everytime...
                              Kind Regards,
                              Morne
