Hi Vlado,
today I've this error and 3ds max crash:
UNHANDLED EXCEPTION: Rendering Region (283,175) -(21,183) Last marker is at ./src/globaillummap.ccpm line 1428 etc...
This happen when the bucket is on some multiscatter object.
I scatter some proxy flower. After some test, I see that if I disable the VRayNormalmap on the flower shader (and all other Multiscatter obj), no crash (cross the finger). I found the problem was on the shader, because when I switch ON "Override mtl" no crash on 10 rendering test. So, I check the shader and I found this bug. It's repeatable. Single Proxy mesh with Normalmap ON no problem.
Last VRay and Multiscatter version. I don't know if is a VRay problem or Multiscatter problem.
Bye
Francesco
Bye
Francesco
