VrayDisplacementModifier error
  • VrayDisplacementModifier error
    i just found out thet the VrayDisplacementModifier is not compatible with the composit map from MAX.
    the simple test is:
    take a noise map and do a 3d displacement rendering on a simple sphere.
    then do that exactly same noise map into a composit map (normal blend mode), and apply the map again to the displacement modifier and have a look what happens.
    well, its not quite what you would expect
    or is there some sort of logic i miss?
    best regards
    MathTheRender
    emoticom AG
    www.emoticom.ch
