Max Autosave while starting render -> freeze
  • #16
    Have you tried to reduce the V-Ray RT performance by dropping the Ray Bundle Size and Rays Per Pixel parameters?
    Which type of engine you are using?
    Does it happen on every scene?
    • #17
      For me I notice the autosave freeze when using BF/LC with the Ray Bundle Size at 16. It also happens when I merge objects into a scene that has RT running but this could be an unavoidable freeze...
      • #18
        I've just tested to merge object into a scene when V-Ray RT is working in both CPU and GPU engines but it was worked fine - could be a scene dependent.
        Have you got a reproducible scene or the issue appears randomly?
        According to the BF/LC rendering - are you rendering with V-Ray RT or with V-Ray Adv with Progressive Image Sampler?
        • #19
          Disregard this, my information was incorrect anyway.
          Regarding the merge-freezes, it's working on my current scene but I'll try to find one that doesn't work.
          • #20
            I think the light I was trying to merge that was causing the crash has become corrupt. It doesn't show up in the viewport and behaves very strangely...
            • #21
              Does the same issue persist if you merge the light when V-Ray isn't working and start it afterwards?
              • #22
                I'm struggling to re-produce it today in the same scene
                • #23
                  It looks like it happens randomly which means that it would be very difficult to reproduce it here.
                  Contact us if the issue appears again and try to capture it in a reproducible scene.
