No Vray edgetex, no Vraytoon...
  • No Vray edgetex, no Vraytoon...
    Hello,
    what's wrong with vray?
    I'm unable to use the vraytoon and the vrayedgetex as they are not listed in the menu!!!
    thanks
    Win7 64 - Vray 2.10.01Click image for larger version
ID:	873114Click image for larger version
    So, nobody can help?
      VRayToon is an atmospheric effect, you should look at Rendering/Environment/Atmosphere/Add...
      Don't know about VRayEdgeTex, I have it here but I'm on 1.5sp6 ... have you tried to type the name in the box that says "Search by Name" in the Material/Map Browser?
        thanks,
        that's exactly my problem (as seen in the screen shot). No Vraytoon in the windows from add effect and no vrayedgetex on the vray map!
          If you look at the 3ds max plugin manager, do you see the respective plugins loaded?
            BTW, the VRayEdgesTex texture is listed in the Standard section of the material browser, not the V-Ray section.
              ok,
              you're right the vrayedge is in the standard.
              But the vraytoon is not listed in the plugin manager!
                Ok then, do you see the path to the additional V-Ray plugins listed at the bottom of the plugin manager?
                  Sorry, it was my mistake. The vraytoon is in the environement tab into the effect instead of the effect tab.
