VFB going crazy in 3dsmax2012
  • VFB going crazy in 3dsmax2012
    Hi there,
    I have 3dsmax2012 installed with hotfix and sp1 updates. Vray 2.0
    In all my scenes, in two different computers, i have lots of problems now with minimizing VFB. It either takes a long time to do it (around 5 secs when it should be instantly like before), and sometimes when scene is heavy or i click twice in minimize, it suddendly goes mad and starts minimizing and pop like there was no tomorrow, and there´s no way to stop it from consistently dropping and popping again....
    Anyone had this problem too lately?
    Thanks.
    Facebook Offical Page
    CG Online Portfolio:
    Gallery
    yep. it happens to me, too. No mention on the AREA forum, so it might be a VRay thing.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      In another thread someone suggests to disable the "progressive refinement" (i'm not sure that are the right words, anyway right click on the box under the Z coordinates) into the viewport settings with nitrous viewport driver.
      This should help to solve the problem
        Thanks!
        Im having some problems finding that setting to be disabled. :/
        Where is that box under Z coordinates?
        Searched in viewport configs and nitrous viewport driver (preferences) but it hasnt anything related to progressive refinement... :/
        Gallery
          I'm sorry..for my bad english.
          As box I mean the "cube" icon used as trigger for the adaptive degradation.
          Anyway, because images are powerful than words, I've attached a screenshot.
          I hope you can solve your problem.
            I'm having an issue after render, where I can't close the window or use max at all for about 2 or 3 minutes.
            Kind Regards,
            Morne
              Bardo!
              Thanks a lot! Its working smoothly, much much better now.
              Gallery
                *forget this post*
                Gallery
                  it seems the Color correction window is causing issues with the VFB. When the Color correction window is open the VFB window looses focus.
                  Bobby Parker
                  phone: 2188206812
                  • Ryzen 9 5900x CPU
                  • ​Windows 11 Pro
                    Well, the focus probably shifts to the color correction window itself. Will check if anything odd happens there, just in case.
