Different RGB Levels On Every Render
  • Different RGB Levels On Every Render
    After I make a full render of the scene, for tweaking certain materials, I make partial renders when the full render is on VFB. I get a different RGB levels for each render- even without changing anything.
    I am on Vray 2.10.01
    for my blog and tutorials:
    www.alfasmyrna.com
    No reply ?
    www.alfasmyrna.com
      Can you show some images? If you are using the light cache for secondary GI with low subdivs, then this is normal - a region render computes less paths for the light cache, so the solution may not be fully converged.
