hair and fur + 3dsmax 2012 + vray
  • hair and fur + 3dsmax 2012 + vray
    has anybody also problems to render hair and fur with max 2012 and vray?
    I thought mprims are compatible with vray and in max 2010 this worked, but with max 2012 it doesn't.
    funnily enough the option "buffer" is rendering the hair but not in max 2010!
    the only option working is "geometry". any ideas?
    thanks
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    If you downloaded the 2012 builds of V-Ray right after the release, they had a bug where the V-Ray rendering plugin was deffered loaded causing the hair not to render. If you re-download the installation it should be fine.
      ah ok.
      thanks.
      best regards
      themaxxer
      Pixelschmiede GmbH
