max 2011 x64, latest vray.
im starting a project where i literally need to render 100's of sq km of landscape in a flyover. im at the stage of testing options, and am looking at the limits of how much i can render in one go, before i have to start splitting the file and comping.
decided to look at using the proxy point cloud system in combination with forestpack.
however when i enable point clouds for a reasonable density tree at real scale, it renders as a set of great big discs, even when close to the camera. i can adjust the render multiplier to get it to render like normal, but the jump from mesh to point cloud, even when distant, is very jarring. the discs are just too big.
i try changing the point cloud export size, but changing from 2 down to 1 didnt make enough of a difference, changing from 1 to .5 made no apparent difference (even the proxy file is the same size on disc, and renders identically to cloud size 1. )
if i try to do a smaller point cloud size ( tried 0.3 and 0.2) max just locks up completely, and the proxy file stays at 1kb on the hard drive.
any suggestions? the point cloud thing sounds great, but im having a hard time getting it to work.
interface wise, it would be great if you could have a min and max distance setting so you can directly set at what distance the LOD change. also the ability to change the point (disc) size without re-exporting the proxy would be nice!
