mix map for bump
  • mix map for bump
    i would think this would work. why not?
    max 2009 vray 1.5 and also max 2012 all 64bit
    I can't check right now but I seem to remember this working just fine. Maybe try piping the mix map through a VrayColor2Bump, this has helped in the past for me for other bump oddities.
    UPDATE: I checked... doesn't work if there's no maps in the mix color slots. A color2bump makes it work though.
      a: i tried putting vray color maps in the slots to test. that didnt work. and i dont see color2bump anywhere
      edit
      ok didnt work with vray color map but worked when i put other maps in it. weird
        Try it in a "Standard" material and see if the bump works in their- not a solution but a troubleshoot at least.
        I know that the "rgb multiplier" map doesn't work in the bump slot which affects BOTH Max "Standard" and Vray Materials.
          i had tried in standard to see if it was vray material but that didnt work either
            mix map in the bump working here with 2 maps in both slots, Max 2009 and 2011?
              i dont get how you get it to work. here i have tried it with 2009 and you can see its not a vray problem but a max problem since neither vray nor scanline can handle mix maps in the bump slot properly. Where am i going wrong
              http://www.youtube.com/watch?v=H1gZUsJey3Y
                Sorry - you can get the Color2Bump map here. Looks like it's a 2.0 thing though.
                  crap. one more reason to upgrade
