light pass composition photoshop
  • light pass composition photoshop
    To all Vray user,
    Can you please share your knowledge regarding light pass composition.
    I've done an interior rendering with different pass for the light (exterior light, sun, ceiling, photometric wall mount...), but I don't understand the physic behind it to recompose the final image in photoshop.
    I found some interesting tutorial regarding GI, Shadow, depht of field pass, but nothing regarding composition of diffrent light.
    I used the Screen layer function in photoshop, but I don't really know what I'm doing.
    Thanks for your help.
    well, if you're after something like what maxwell and fryrende do with lights in post, you should be rendering one image per light (or group of lights), as I guess you did, save to a hdr format, and then add all of them together. as you work linearly, the correct operation/blending mode, is add not screen.
      Yes, that's what I'm looking for, a flexible solution to fine tune the light live.
      Do you mean Linear dodge (add)?
      Thanks
        yep, that's the one. still can't understand why they can't just call it add, as for any other app..
          In nuke it's called plus [/nitpick]
          At leat it's an equivalent name
            eh, yes it's the idea that counts
            linear dodge sounds more like the opposite, either that or it's totally meaningless..
              Ok, what about Autodesk Composite? You, guys, seems to use Nuke/fusion... and I do not own license but I do have composite. Any idea how to do it in composite?
                Yes, mix them together with a Blend & Comp node set to ADD and you'll get the same result in Composite.
                Colin Senner
                  Holy cow! I didn't know we can do this?
                  Bobby Parker
                  www.bobby-parker.com
                  e-mail: info@bobby-parker.com
                  phone: 2188206812
                  My current hardware setup:
                  • Ryzen 9 5900x CPU
                  • 128gb Vengeance RGB Pro RAM
                  • NVIDIA GeForce RTX 4090 X2
                  • ​Windows 11 Pro
                    I'm not composite expert, but I did watch the tutorial videos :P
                    Colin Senner
                      and I suppose we can animate lights coming on in After effects? Any good tutorials on that?
                      Bobby Parker
                      phone: 2188206812
                      • Ryzen 9 5900x CPU
                      • ​Windows 11 Pro
                        thanks, I will try to see if it's more easy to handle than photoshop when playing with 20 layers.
                        What tutorial are you refering to?
                          It's hard to find tutorial videos online of Autodesk (newly renamed Composite). Search for "Toxik tutorial". Here's one.
                          http://www.youtube.com/watch?v=PZNFt_GHeIo
                          Hope this helps. I don't love Composite by any means. Nuke is much better, however, Composite is free, so I've taken to trying it out.
                          If you have any Composite (Toxik) questions, let me know.
                          Colin Senner
                            I have After Effects. Is Nuke better that AE, or is it apples-to-apples.
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #15
                              Nuke is the best compositing software in the world.
                              After Effects does _alright_ compositing (it's easy enough to get similar results, and very hard to get exact results).
                              Nuke costs $5000 USD. AE is considerably cheaper.
                              If you're doing compositing, use Nuke, or Toxik (renamed Composite, now ships with MAX), if you're doing motion graphics or just color correcting some footage and adding text, use AE.
                              Just my 0.02
                              Colin Senner
