How Can I Render Bloom as Separate Pass?
  • How Can I Render Bloom as Separate Pass?
    ( I didn't get a response from anyone from Chaosgroup on this when I posted it in the General tab, so Im re-posting here hoping I'll get a response)
    On 2.0 I turned on the Vray Lens Effect, enabled Bloom, and turned on "Render Element" under the bloom options. Im rendering out EXRs and from what I understand the Bloom Render Element created by VRay Lens Effect is NOT stored in the EXR. This is evident because when I extract the bloom in After Effects, its empty. Thus, how can I save a separate pass for the Bloom?
    It's my understanding, you can't.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
      There was a discussion a while back; at the moment, you need to use the 3ds Max frame buffer for this to work. This is because the lens effect is applied after the render is complete; but on the other hand the raw .vrimg and .exr files are written *while* the render is being done, before the lens effect.
