Urgent !! VrayProxy Mesh Aren't smooth ?
  • Urgent !! VrayProxy Mesh Aren't smooth ?
    i've a big issue that i need to solve very urgently
    I'm creating some proxy of animated mesh. But i lost the Smooth !
    the Left is proxy, the right is the original.
    I've try to redo it with Turbosmooth on top before making proxy. It's not help .
    I'm using VRAY 2 with 3DSMAX2012 x64.
    thanks for your help !
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    Looks like just one of the meshes is not smooth. Is that object mirrored?
      Hello Vlado,
      thanks from coming to help me !! I need to solve this very shortly.
      My mesh is an extruded text . I had converted to poly and do some modeling.
      Then i have try to clean it up with Reset Xform.
      so, it's now a mesh . it's full unsmoothed !! the on wich is smooth on my picture is the original mesh .
      I must use Vray proxy because it's the only way i find to work with this animation without waiting 3 minutes between each frame on viewport.
      It's just a text with many boolean animations made with ProBoolean . but 3DSMAX can't work with this on viewport .
      I've try to export as a OBJ sequence, but 3DSMAX have some slowiness too with HD Obj sequence.
      With Vray proxy i can work and duplicate the animated mesh . but i can't have the smooth wich is really important for this project .
      freelance 3D artist
      www.ghiom.com
        Can Boolean animation beeing the problem ?
        freelance 3D artist
        www.ghiom.com
          Ok then; unfortunately I don't have an immediate idea of what is going on - if you have the time, please send me a file with just the mesh to vlado@chaosgroup.com and I'll see what can be done about it.
            Thanks you Vlado , i'm working on an other workstation and it's seems to beeing smooth .
            Maybe some VRAY files aren't correctly updated when i apply updates on my worksation ?
            So thanks for your help, it's just great to having you when we need you !!
            I must finish my animation to start rendering and i will back to undrstand what happening later .
            Thanks for your kindness !
            freelance 3D artist
            www.ghiom.com
