3ds viz 2008 & vray on 64 bit machine
  • 3ds viz 2008 & vray on 64 bit machine
    Can anyone help me with my dilema? I'm running 3ds Viz 2008 on a 64bit windows OS and I just can't get vray to install. I keep getting either 'failed to locate .dll files' errors when I open VIZ or vray simply won't install. Can anyone tell me which Vray build I should be installing? I just can't figure it out.
    many thanks
    Is it penry....the mild mannered janitor?
    If you right-click on 3dsviz.exe, and select properties, then go to the "Details" tab, what is the "Product version" field?
      product version field reads 9.0.0.36
        I guess you need V-Ray for 3ds Max 9 then - is this the one you are installing?
          I've lost track of which build I've tried to install. When you say 3ds Max 9 do you mean Max09 or Max 2009?
            I mean max 9, not 2009. The installation should be called something like vray_adv_20004_max90_x86.exe or similar.
            Did VIZ 2008 have a 64-bit version? Or just a 32-bit one?
              The VIZ software is pre Windows 7 which is the OS on my machine! It offers both 32bit and 64bit versions for Vista but when I install it directs the installation straight to the 'Programs x86' folder which leads me to believe it's installing as a 32bit programme...? Is this right? If so I'm stumped.
              HELP!
                I can now install Vray using the build you suggested Vlado (thankyou) but once vray is installed I get a 'can't start Setup64.exe' message and none of the WIBU drivers are installed.......damn it! Any ideas?
                Thanks
                  You can get the WIBU drivers separately from here: http://www.wibu.com/downloads-user-software.html
                  You need the WibuKey Runtime for Windows - 32- or 64-bit depending on your Windows version (not the 3ds VIZ version).
                    I've had enough of this wibu key. Now I can't install the hardware usb dongle because it won't recognise any installed drivers. I've chequed the FAQ page on WIBU systems website and they say search for the .inf file-this file is missing from my PC.Really don't know what's happening here....should have bought a 32bit machine instead!
                      Can you tell me which file you downloaded and installed? After all, I also have a 64-bit Windows 7 machine installed, with various 32-bit versions of 3ds Max and V-Ray and they work fine.
