I am having a problem using a Vrmap sequence in Animation (rendering).
I created the sequence in Animation (prepass) and am now trying to render it using Animation (rendering).
It is something to do with the vrmap sequence using numbers above 9999.
I can render out with vrmaps up to 9999 but if the vrmap has 5 figures after the name then backburner won't load the vrmap.
Image9999.vrmap works but with Image10000.vrmap I get the message in backburner "Could not load irradiance map".
It seems to be a backburner problem as it will render OK on a single machine without backburner.
Using Max Design 2010 SP1 64
Backburner 2008.1.1
Thanks,
Hugh
Backburner 2008.1.1
Thanks,
Hugh
