Subscription Advantage Pack breaks DR?
  • Subscription Advantage Pack breaks DR?
    DR stopped working after installing Subscription Advantage Pack for Autodesk 3ds Max 2012 64Bit on vray2.0.
    In the task manager of the DR machines you can see how the spawner loads the 3dsmax process,
    after some time the process quits and is started again by the spawner.
    This happens in a loop.
    After uninstalling the advantage pack and restarting the service, DR works again.
    I tried it on six PCs.
    Anyone else has this problem?
    Reflect, repent and reboot.
    Order shall return.
    Have you tried running a regular backburner rendering with the render slaves after installing the advantage pack?
      Yes, backburner rendering works with the advantage pack.
      Order shall return.
        Ok; then it might be that we need to update the vrayspawner.xml file - I will check it out on Monday.
          I did a quick test on my one node and it seems to be working fine for me. So no issues thus far.
            no issues here.
            Bobby Parker
            www.bobby-parker.com
            e-mail: info@bobby-parker.com
            phone: 2188206812
            My current hardware setup:
            • Ryzen 9 5900x CPU
            • 128gb Vengeance RGB Pro RAM
            • NVIDIA GeForce RTX 4090 X2
            • ​Windows 11 Pro
              all good for me too.
              Brett Simms
              www.heavyartillery.com
              e: brett@heavyartillery.com
                Hi tammo,
                I cannot reproduce the problem here. Is there some else product installed on the DR hosts that could possibly be messing with the distributed rendering?
                Also on the DR host machine in the user's temp directory, which should be something like: "C:\Users\<username>\AppData\Local\Temp" there are some files "VRSpawner.log", "vraylog.txt" and eventually "3dsmax_minidump.dmp", could you send them to alexander@chaosgroup.com, maybe they could provide some info on the problem. And in the 3ds Max program files folder ("C:\Program Files\Autodesk\3ds Max 2012" for example) there you must have two files "vraydummy2012.max" and "vraydummy2012.xml", which come with the V-Ray installation and are mandatory for the DR host to work properly, could you check and send them too please?
                Aleksandar
                Alexander Kazandzhiev
                V-Ray for 3ds Max developer
                  There is also the "Max.log" file somewhere in the local users settings folder, which might provide additional information.
                    I have notice that my nodes have been timing out when I go to restart them. This has never happened before, but they do start when I start the service a second time.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Vlado, did you manage to take a look at this? Just spent 3 hours messing about with user permissions to no avail, then spotted this post, uninstalled the advantage pack and slaves work again! What's going on??
                        Yes, but unfortunately like the others in the thread, we could not reproduce it. Can you show me the Max.log file from the this folder "C:\Users\[...]\AppData\Local\Autodesk\3dsMax\2012 - 64bit\enu\Network" - it might contain some useful information.
                          No problem, I've just e-mailed it to you. I had a look at it but I don't think it gives much information on the error.
                            Thanks, we could reproduce the problem now and one of our developers is looking into it.
                            • #15
                              Hi!
                              Has this been fixed, or is there a way how to make the subscription pack work with DR?
                              Unfortunately i couldn't send you the log-files because i had already uninstalled most stuff in order to get the current project done.
                              Order shall return.
