I have had this error occur intermittently in Vray 2.0 SP1, when trying to write an EXR file (with render elements) to my local Hard drive, through the frame buffer. This particular instance, it was a large image file (7000pixels wide), but I have had this occur with much smaller sizes as well. Log reads:
"error:{VFBCore::SetRegion} Error writing render region to raw image file. {ExrFile::WTRegion} Error writing tile to .exr file"
I can save the files out manually through the FB by writing to a .vrimg file and then converting, but obviously none of the render elements come through, and so they also have to be saved out manually too. I found this used to be a common issue before Vray SP1 when trying to write files over a network, but wasn't an issue as long as the file path was to a local hard drive.
Machine specs: Windows 7, 3ds max 2012 SP2/HF2, Vray 2.0 SP1.0
Any ideas?
Any ideas?
