hi All,
i found this problem. I use LWF and often when i use dark color, with fresnel reflection, in the editor and in the render, i see the problem in image cutoffA001. My gradient reflection ( driven by fresnel parameter)seems to be "cutted".
If i pull down CUTOFF value to 0,001 instead of 0,01 ( default) things are ok ( also in render).
So, my question is: is better to use cutoff always set to 0,001? this slow down rendering times?
Regards.
Regards.
