error: [VFBCore::SetRegion] - but no region set!
  • error: [VFBCore::SetRegion] - but no region set!
    error: [VFBCore::SetRegion] Error writing render region to raw image file. [ExrFile::WTRegion] Error writing tile to .exr file
    OK so I got this error on 2 different machines rendering 2 different views for the same job. I remember couple of VRay versions back something similar was cause when you set max to render a region. But this is not the case. It is set to render "view" and the view is the VRayPhysical Camera
    The job finished render, but the EXR didn't save the last few buckets I'm geussing. But WHY? Luckily Icould save the VFB as a tga file.
    Max 2012 64bit
    Max Design 2012 64bit
    VRay 2.0 sp1
    Kind Regards,
    Morne
    I eventually just switched to using vrimg files instead of exr to avoid this one. It's a pain, but the vrimg file is more bullet proof.
    /b
    Brett Simms
    www.heavyartillery.com
    e: brett@heavyartillery.com
      So this is a known issue then? When is it getting fixed?
      Kind Regards,
      Morne
