vrayphysicalcamera with clipping goes foll
  • vrayphysicalcamera with clipping goes foll
    I do face a critical problem with vrayphysical and clipping.
    What I see in the viewport is the result of the clipping vrayphysicalcamera, but when I render it (same camera as the viewport) thyre is no clipping at all.
    Any idea?
    I tried to put another physical camera with clipping, same result.
    I used that trick given in another post:
    [QUOTE=ruud3dv;449122]You only have to delete all the animation keys for 'clip_on', then turn it on in camera properties (without Auto Key enabled) so it's always on and not animated.
    But the result is the same. So far no progress.
      Can you post a scene with this error?
        Sure I can, but last scene (an urgent work for an difficult client) sent to Chaos group tooks more than 3 months to got a feedback from the support and I'm still not sure the problem as been solve as I need to installed the 2.15.
        The only think I'm sure is that I have to give a 50% to the client to avoid to lost him due to bugs in Vray 2 render and the bad chaos group support policy!
          It might help if you also email me to vlado@chaosgroup.com (and keep emailing until you get the issue resolved ); there's a lot of work to be done and as much as we try, unfortunately sometimes things slip through.
