I am just starting to learn to composite render elements using Vray and Photoshop CS5. In the attached testexr_comp file you can see a white fringe around the square and the cone. In the testexr_beauty pass, I do not see it. I tested this using 32 bit and 16 bit exr. I also see it when using PSD Manager and saving either 16 bit or 32 bit PSD files. Turning on or off pre-multiplied alpha seems to have no effect. I have also searched the web for a solution but have found nothing. What may I possibly be doing wrong?
Thank you very much,
David
David
