Error retrieving configuration file
  • Error retrieving configuration file
    Hi all
    I have a hell of a ride behind me... i wasen't able to setup my backburner because of the "Error retrieving configuration file" prompt.
    now all i found was this, which got me close to a solution:
    http://area.autodesk.com/forum/autod...ile/page-last/
    telling me this:
    "I’ve solved my problem !
    I replace the backburner.xml file in
    C:\Users\"username"\AppData\Local\Autodesk\3dsMax\ 2012 - 64bit\enu\BackBurner (3ko)
    by the one in
    C:\Users\"username"\AppData\Local\backburner (8ko)
    (these paths are for windows 7)
    and it worked immediately (no need to restart max)
    but i have max design and it diden't fix it at all...
    so i had the idea of organizing e an backburner.xml file from the normal max and not the design edition.
    and now it works!
    here the xml:
    backburner.xml.txt
    so you got it fixed faster than me
    best regards
    MathTheRender
    emoticom AG
    www.emoticom.ch
