Vray Camera zooming ang offseting problem
  • Vray Camera zooming ang offseting problem
    Hi Vlado. Im using vray 2.20.03 x64 for 3dsmax 2012 and I tryed zoom factor and offset parameter for the camera, but the rendering is not matching what i see in viewport. Is it the bug or it is not working only for me?
    Thanks a lot
    Make sure to turn on safe frames... probably the culprit.
    I once hand tracked an entire 900 frame sequence without safe frames on... ugh. Never again.
      A character building experience by the sounds of it...
        This was not my problem, safe frame was on ofcourse
          It happens to me too but in old scene in newer version of vray its camera gave that problem. Building a newer one and aligning it with the older I solved. Hope it helps
          Workstation: Asus p9x79WS I7 3930K Noctua NH-D14@4200GHz SE2011 16GB RAM Kingston Hyperx Beast SSD 500Gb Samsung x2 SATA3 WD raid edition4 64MB GTX760 2GB DDR5 CoolerMaster 690III
          https://www.facebook.com/essetreddi..../photos_albums
