AA Problem With "Dont Affect Colors-Adaptation Only"
  • AA Problem With "Dont Affect Colors-Adaptation Only"
    I can't get a good AA when there is a bright point near some lower value pixels. I tried everything including subpixel mapping and clamping output but only the workaround was to fake it in Photoshop for me.
    Today I discovered that AA problem mostly appears when "Dont Affect Colors-Adaptation Only" is checked.
    Below are 2 renders: for both of them
    subpixel mapping enabled
    exponential color mapping (so didnt enable clamp output)
    As you see below,
    The one with "Dont Affect Colors-Adaptation Only" has AA problems.
ID:	874029Click image for larger version
    for my blog and tutorials:
    www.alfasmyrna.com
    Normally clamping to 1 or slightly above one should fix this as the renderer has problems to sample proper if the difference between the pixels is too large. Works for me all the time.
    http://www.andreas-reimer.de
    http://www.renderpal.com
    my HDRI and texture collection
      Originally posted by pixela View Post
      As you see below, the one with "Dont Affect Colors-Adaptation Only" has AA problems.
      It's normal - the exponential color mapping and the subpixel mapping in the first case smooth out the AA, but if you don't apply them to the image (i.e. the "Don't affect colors" option is enabled), then obviously their effect is gone.
      Vldao
        Vldao
        I know "Don't affect colors" disables the effect of Type (Linear mult., Exp...), is also disabling the Sub pixel mapping effect?
          Vldao
          I didn't know that "Don't Affect Colors-Adaptation Only" cancels subpixel mapping or any kind of color mapping.
          Now I understand better.
          Does it also override enabling "Clamp Output = 3 (for example) ?
          www.alfasmyrna.com
            No, clamping is not affected, just the color mapping itself. Clamping will still work.
              Man... this explains so much. Been having weird issues with this and I thought I was going crazy.
                maybe these options should be greyed out when "don't affect color" is checked
                Alessandro
                  Same here, never figured that one out and also thought I was a little nuts a few times...I also like the idea of greying out, as Alessandro suggested.
                    Why should they? They still affect the way V-Ray performs adaptive sampling. This was the purpose for adding the "don't affect colors" option - people wanted the color mapping to affect the sampling (i.e. the noise levels), but not to influence the final colors.
                      sorry, I probably misunderstood something but your lines above sounded different
                      Vldao
                      a further clearification could be useful because in the helpfile I can read:
                      Don't affect colors (adaptation only) - when this parameter is on, the color mapping will not be applied to the final image, however V-Ray will proceed with all its calculations as though color mapping is applied (e.g. the noise levels will be corrected accordingly). This can be useful, for example, if you know that you will apply some color correction to the image later on, but wish to keep the rendering itself in linear space for compositing purposes. Note that the Clamp output option will have an effect regardless of the value of the Don't affect colors option.
                      there is nothing that talks about subpixel mapping
                      that said, I understand that disable them it's not a good idea
                      Alessandro
                        So if I am understanding you, it's good for when we are rendering 32bit (say exr's) that we want to output at gamma 1.0 for the render elements, and do the corrections in post? (But the noise sampling knows that we are correcting in post.)
                          Yes, this is correct.
