VRayColor2Bump / Vray Adv 2.20.03 and object scale
  • VRayColor2Bump / Vray Adv 2.20.03 and object scale
    VRayColor2Bump work as a normal converter for B&W maps, correct me if I'm wrong.
    It work great, better than directly using B&W map into bump... It's close to awesomeness !!! very close !!!
    BUT, I get a terrible issue, when doing very high resolution, bump disappear.
    I've got this issue with max bitmap and vrayHDRI.
    When up-scaling the object from 1 to 10, problem disappear, maybe there is a clamp or something in the VRayColor2Bump.
    Is there any chance to see a fix quickly, because I'm currently working with this feature and I can achieve the same render without it.
    We recently made heavy use of VRayColor2Bump and can't go back quickly.
    I can't work with up-scaled objects because I working for industrial purpose and It's too hard to work with wrong scale. Based objects are 3.5 cm high.
    Here are some examples : (Very noisy because of a very low setup)
    4000px x 4000px :
    4500px x 4500px : less bump in the center
    5500px x 5500px : even worth
    Hope you can fix it !!! best regards.
    My Flickr
    Yes, I can fix it, but can you get me a scene where I can reproduce the problem?
      here is a test scene with bug : (max 2011)
      1 Cam, lights and 1 object.
      http://www.digitalsoap.ch/le-truc/Vr...Color2Bump.max
      My Flickr
        Thanks, do you need the fix for 3ds Max 2011 64-bit?
          Yep !!! it is the only version we are currently using
          My Flickr
            Ok then, please find attached a recompile - drop it into the [maxroot]\plugins\vrayplugins folder with the rest of the V-Ray plugins. Let me know if there are any other issues.
              No more problem at 6000px x 6000px. I'm planning to do more test, and I tell you...
              Thank you very much !!!!!! Chaos Team is always the best !
              Your awesomeness is awesome !!!
              Best regards !
              My Flickr
