DR nodes going Idle after a couple frames
  • DR nodes going Idle after a couple frames
    Yesterday, I thought I had solved the problem of my DR nodes dropping out. It appeared that rebooting them fixed it. Today, however, they are back to misbehaving.
    By now there must be a list of items which can cause this to happen. It would be very helpful if one could be posted as a 'Sticky' item in the forums.
    In the meantime. Can someone point me to such a list if it exists? I'm going crazy over here.
    Don't render final image - checked
    max 2012, vray 2.20.03
    rendering every 30 frames of 720 (25 frames).
    animated camera only.
    spawner is running as a service.
    File consist of multiple xrefed scenes.
    resolution is 1920x1080
    render slaves will render for the first 2,3 or so frames then go idle.
    ....gregory
    gregory mertens
    http://mertens3d.com
    my VRay Bugs/Issues/Request List http://mertens3d.com/blog/?p=238
    and everyting is fine if you run spawner manually instead of a service?
    Kind Regards,
    Morne
      I have not tried that. But I can.
      Is running it as a service a known issue?
      gregory mertens
        Starting it manually will show if it's stable or the icon appears and then dispersers again.
        Can you send an e-mail with more details about the issue and the vraylog file from the server and the problematic nodes to support@chaosgroup.com
          Marta,
          I have emailed some info. Please let me know if there is anything else that would help you to solve this.
          I believe the icon remained on the entire time.
          ...gregory
          gregory mertens
