Using Max design 2012 x64 (win 7) with Vray 2.20.01
The Vrayzdepth pass, is being displayed with heavy noise in the alpha zero areas of the render in the Vray frame buffer:
If I change the image sampler from Adaptive DMC to adaptive subdivision the noise becomes limited to just the edges of the object:
If I change to fixed (subdivs: 1) the noise vanishes completely.
It seems that the noise only appears wherever there is more than 1 subdiv of image sampling, in areas of alpha zero.
I have tried to recreate this anomaly in a fresh max scene without success.
Note: this issue is only seen in the Vray frame buffer. The files saved from the render pass are perfect.
Has anyone else encountered this?
Cheers
Cheers
