Point cache problem, urgent!
  • Point cache problem, urgent!
    Hi all,
    I have to render an animation when I used Point Cache, the problem is that some of my computers from renderfarm dosen't seem to 'load' pointcache.
    I use DR method for rendering, does the PC file need to be in specific folder?
    there are on the network path start on :\\...
    is that may be vray issue or rather network problem on few computers?
    is even more strange as the computers which dosent 'pick up' PC file render the meshes with all the textures, lighting ect...
    anybody can help?
    thanks,
    peter
    Peter Kolus
    Senior 3D artist / CG Generalist
    www.peterkolus.com
    Why are you using DR for rendering an animation?
    You would be better off using backburner
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      yes I know, but in this case let just say I'm using DR,
      we have software called 'smedge' instead of backburner but the problem is the same..
      Peter Kolus
      www.peterkolus.com
        Have you tried using animated vray proxies rather than point cache?
        Chris Jackson
        Shiftmedia
          no and I don't have time for it right now, but I will have this option in mind next time, thanks
          Peter Kolus
          www.peterkolus.com
            It is quite easy to convert point cache to an animated proxy.
            Right click on the object.....
            Chris Jackson
            Shiftmedia
              ah ok, thanks a lot, I will then give it quick try!
              thanks jacksc02!
              Peter Kolus
              www.peterkolus.com
                I've had this problem once before, I ended up copying & re-directing the cache file to each machine locally. I realise that's not a great solution but if you're up against it it might help!
                MDI Digital
                moonjam
                  Relink all point cache on a network patch. Works perfectly here since years
                  http://tatprod.com/
