Vray displacement modifier and motion blur turns an object black.
  • Vray displacement modifier and motion blur turns an object black.
    Max 2012 Vray 2
    I have a problem whereby I have an editable mesh which has a pointcache, a turbosmooth and a vray displacement modifier (2D displacement). Using a standard Max camera. If I render without motion blur all is good. If I render with motion blur some parts of the object render black. If I turn off the displacement it renders fine.
    I have tried turning off the various modifiers and have isolated it as a combination of the displacement and the motion blur.
    Has any one come across this and is there a known solution?
    Many thanks in advance.
    Regards
    Grant
    can you show us a part of your render?
    also are you motion blurring between frames? i.e. have you tried with duration of .5?
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      I can't show you right now, I am rendering at duration .3.
      Interestingly using a Vray physical camera it is not a problem. But due to our pipeline that is not an option. So it is directly related to the 3DSMAX standard camera.
      Regards
      Grant
      Cheers
        What are your motion blur settings - interval center, duration?
          Duration 0.3
          Interval Centre 0.0
          Bias 0.0
          Subdivs 6
          Prepass 1
          Geometry samples 2
          Blur particles as mesh NO
            Then try setting the interval center to 0.15; maybe the physical camera works because it sets the motion blur interval entirely within a frame.
              Thanks for that,
              I'll have a look at that and see what happens.
              The geometry, which is the only piece in the scene that is affected, is very angular, a bit like a 7 pointed star, so I think it is possibly flipping some normals or creating some intersections that are not happy wen displaced.
              I'll keep you posted and when I get the chance I will post a cleaned up scene for you to have a look at.
              Really appreciate your participation.
              Many thanks
              Grant
