Multiscatter and V-ray 2.30.01
  • Multiscatter and V-ray 2.30.01
    I've just updated to the latest v-ray build and found out that multiscater isn't rendering. Anyone tried it yet? I'm not sure if it's a problem specific to my configuration or it's just an incompatibility between the new V-ray and the latest MS build (dating feb 22,2012.). I've asked on the R&D MS forum but they are notoriously slow on responses.
    The V-Ray SDK is compatible between 2.20 and 2.30 - we haven't changed anything in that regard.
      Since I've moved to max 2012 recently I was doing some tests a few days ago. Everything worked fine. I just can't recall If I were using the latest v-ray build. I'll give another try on a different machine... Anyhow, it's pretty strange that it doesn't work...
        Well.. It doesn't work. Somehow seems it's related to the MS plugin not working with the new V-ray.
          Multiscatter needs to be recompiled for max 2013 and for the new VRay SDK.
          Karba will probably get on to it sometime soon.... maybe....
          Chris Jackson
          Shiftmedia
          www.shiftmedia.sydney
            It will need a recompile for 3ds Max 2013 for sure, but it should fine for 3ds Max 2012.
              Multiscatter (annoyingly) has a version check before vray can render and currently it is locked to VRay 2.2
              Chris Jackson
              Shiftmedia
                figures... I'll have to revert back to V-ray 2.2... damn. At least they could track and anticipate new v-ray releases (that are far less common than Autodesk app new releases) since it's a plugin developed from Vrayscatter.
