vray scene converter - material rename
  • vray scene converter - material rename
    when converting all materials in the scene the converter put a word "vray" in front of the material name... it's a no go in my scene, because if I import models again, the materials are not recognized again because the name is not the same anymore...
    I search a way to remove the word "vray" per batch (script). any ideas?
    thanks for helping.
    best regards
    themaxxer
    Pixelschmiede GmbH
    www.pixelschmiede.ch
    If you find a solution, please post it here as I'm also interested in that...
    Kind Regards,
    Morne
      While you wait for a more convenient solution, you can try the the following:
      - Close Max
      - Search for a file called "vrayutils.ms" (mine is at "c:\Program Files\Autodesk\3ds Max 2010\Scripts\Startup\")
      - Search for the line that says:
      Code:
      r.name="vray "+origMtl.name
      and change it to:
      Code:
      r.name=origMtl.name
      Regards
        You can also use this snippet to remove "vray" from the already converted scripts:
        Code:
        for o in scenematerials where (substring o.name 1 5 == "vray ") do (o.name = substring o.name 6 -1)
          Like Codi suggested, you can simply modify the converter script...
            great! thank you guys for your help! it saves me a lot of work.
            best regards
            themaxxer
            Pixelschmiede GmbH
