Excluding vraylights from ao
  • Excluding vraylights from ao
    Hi!
    Is there any way to exclude VrayLights from the ambient occlusion-element (VrayExtraTex with VRayDirt applied)?
    Lights do not appear on the exclude-list. Also using "include" for geometry does not exclude lights.
    I've bumped into this problem a couple of times, when light planes overlap with ground geometry etc.
    Thanks in advance,
    - Teemu
    TD at http://brinkhelsinki.fi
    3ds Max 2013 with VRay 2.30.01.
    Win 7, Intel Xeon X5675, Nvidia Quadro 5000, 48 gb ram.
    Try to set V-Ray light to invisible and check "work with transparency" option in V-Ray Dirt map, this should work in your case.
    Tashko Zashev | chaos.com
      That did it!
      Thanks a lot,
      - Teemu
