Vray2-sided material not respecting-use irradiance map option in nested vray material
  • Vray2-sided material not respecting-use irradiance map option in nested vray material
    I just did some testing & it appears that the Vray2-sided material is not the respecting-use irradiance map option in nested vray material. If the use IR map option is off Vray still uses the IRmap if the VrayMtl is a sub-map of the 2Sided material. Does the 2sided material also need a checkbox for this option or should it just do it by default????
    Kind regards
    Jamie
    It should do it by default, I'll make a note to fix this.
      Thanks Vlado
