PSD Manager Slow to kill
  • PSD Manager Slow to kill
    Has anybody been experiencing PSD Manager taking forever to cancel? When I cancel a render it'll sit at PSD Manager for about 5 minutes.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    There was a V-Ray bug related to aborting a render, but a workaround is already in psd-manager since 3.0. So i guess that is not it.
    Details and workaround can be found here: V-Ray bug, first render effects called even when render was aborted
    Did you try to cancel mid-render or after the actual render while psd-manager writes the PSD?
    V-Ray, psd-manger, 3ds max versions used?
    What does your render progress bar look like while you wait, does it move?
    Really 5 minutes or does it just feel like 5 minutes?
    If you canceled mid-render psd-manager will detect that and do nothing. Maybe the render progress dialog just still shows the "psd-manager" text while V-Ray does some other cleanup. (Try adding an empty FileOutput effect before and after psd-manager to check if this is the case.)
    While the PSD is already written the render can not be aborted currently (like all other file formats I believe). The file is written on the fly and you would be left with a broken PSD file otherwise.
    Best Regards,
    Daniel
    PS: From reading the title I first thought your psd-manager is slow and you want to kill someone - feeling atleast safer now
    Daniel Schmidt - Developer of psd-manager
      well... I feel like killing something! It sits at, "Current Task: psd-manager" for more than 5 minutes (it seems like an hour). It's a large scene, with a ton of proxies, but it's still frustrating.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I'm happy to help, but so far I don't have any details (see questions above).
        Email: mail@daniel-schmidt.biz
        Skype: daniel_schmidt
        Best Regards,
        Daniel
          mid-render
          3DS MAX Design 2013, v-ray 2.30.01 and psd-manager 3.2
          the progress bar is where the LC left it, or sometimes the bar is just blank.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            If you cancel mid-render then V-Ray should not even call any render effect (that's the old V-Ray bug i pointed to above). Whatever, psd-manager doesn't do anything at that point because it also checks itself if the render was cancelled to workaound that. This is the first line form the psd-manager code.
            Code:
            if(checkAbort && checkAbort->Check()) return;
            It checks if the render was cancelled and is done. So V-Ray or 3ds max is doing some cleanup after the render and the text "psd-manager" is just not removed/updated until the render progress windows is closed. Add any other render effect (e.g. just an FileOutput) before and after psd-manager and you will probably see that effect's name shown instead.
            I noticed another V-ray thread Max-2013-sluggish-just-after-render. Could that be related?
            Best Regards,
            Daniel
